Sign Up! To view all forums and unlock additional cool features
Once the connectors have been unplugged, you can now proceed with the removal of the light bar.
To do so you will to get you plastic panel remover too and insert it on to the side of the light bar.
You don't have to do this. There is no reason to pry the light bar from the outside. Once you have removed the nuts and connections, gently push on the studs (where you removed the nuts) on either side of the bar and it will pop loose.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
